sharp arm 450/ imagistic 4510
  • jpcopy
    • Apr 2006
    • 256
    got a couple of machines that give a falses paper empty in the #1 cassette. Is this a tray setting adjustment like tray # 2 or do I have a problem that needs addressing any help appreciated
    jp
  • ravikumarj
    • Apr 2007
    • 49
    jp
    Have u interchanged the cassette and tried ?
    Have you reset the procedure PICI 14 intiated?
    Also you may interchange the paper feed assembly and check the sensor actuators?
    Try please
    Ravi.
    • jpcopy
      • Apr 2006
      • 256
      no I haven't but I'll give it a try
      thanks
      • davidhackler
        AR-M450
        I have had problems with the lift-up motors, also have you tired sim 30-2?
        • ravikumarj
          • Apr 2007
          • 49
          Sharp AR450
          You may intiate the simulation 14 and excute.
          Have you tried this?
          • davidhackler
            AR-M450U
            Sim 14 only clears codes, sim 4 (1), (2) and (3) checks the motor and sensors of the deck paper feed/large capacity tray ( page 9-3 sharp AR-M350/450 service manual). There is a updated lift up motor (per sharpnet). We have had a few machines with this type of problems, mostly from the first (small) tray, but I have had to change some out on the desk units. Also you can try adjusting the paper sensors by using Sim 40-12 (page 9-33 Sharp AR-M350/450 service manual)
            • jpcopy
              • Apr 2006
              • 256
              Thanks guys we'll check it out. motors and sensor work. it's tray 1
              runs one copy and says add paper. hit ok and open and close tray may run one copy and may run several we blew sensors out (though we already had) and no problems yet
              • robycopy
                • 10
                I've got a problem U6-02 from AR-M350 and after swap the motors and sensors, tried simulations procedures, etc. I swap the PCU board with another machine that had not LCD, but trays 3 and 4. They both still working.
                • dqydj
                  • Jun 2005
                  • 65
                  I'm confused?
                  Which is still working? The machine with the LCT or the one
                  with the 2 drawer base?
                  Both machines?
                  I'm lost...
                  • robycopy
                    • 10
                    I'm sorry. I didn't mean to say that fast and was really bad. Machine 1 had LCT, but gave me code U6-02. Machine 2 had four trays ( no LCT ) and was working ok. Because I had those two machines in the same room, I've decided, after exhaustively trying other options, to swap the ICU boards between them. The ICU from 2 is now working on machine 1 beautifully, and the ICU that was on 1 now is working on machine number 2 wonderfully.
