View Full Version : bizhub c250 admin code
mtech
04-05-2010, 04:01 AM
Anyone recall what the default admin code for the bizhub c250 is? Also if it has been changed is there any way to reset it or get it back. I can't seem to remember.
default admin code 12345678
gabski
02-18-2011, 08:55 AM
if 12345678 wont work, try 00000000
huntergazz
02-18-2011, 11:39 AM
Hi,
You can also access the service mode by turning the machine off at the keypad then the main power switch behind the front door.
then...
turn on the keypad switch
hold utility counter button
turn on the main power switch
a black dot will appear on the screen
after that there will be an option for system error clear
at that point press stop 0 0 stop 0 1
enter 92729272 and the service mode will be diplayed. you can change the admin password in there.
if that doesnt work you will need to re-set the nvram
Philinghorn
02-18-2011, 12:18 PM
Thanks guys for all your replies. Customer has "remembered" the password.
Cheers
Stirton.M
02-19-2011, 09:32 PM
The admin code can be reset in tech rep, security mode "stop - zero - clear"
