eurosears
04-07-2010, 08:06 AM
I recently got the IP-432 controller for my Konica 7145. It works fine, I can print from the PC, scan PDF's to the PC, etc. However, when I scan pages to memory (doing a whole book for example) the memory gets full after about 40-60 pages or sometimes even less and then I am unable to transfer these pages to the computer. The memory percent counter goes from 100% to 71% after first scan, then decreases 1% every 3-4 pages. Once I hit 63% (or there abouts) the memory gets full and the copier doesn't (or I can't send it) send any PDF's to the computer. I have to start over again. However, If I don't reach the maximum, and after about 20 copies I send the PDF to my computer I usually do not have any problem. Is this normal? Is there a fix to this or work around (e.g., setting up a automatic send once the memory is almost full).
Also, the controller doesn't have a hard drive installed. What is the purpose for having a hard drive in these boards. Could I, for example, scan PDF's to the hard drive first and then send the file to PC?
What type of hard drives can I plug into these controllers? Are they just the standard IDE type or something else?
Thank you.
Robert
Thank you.
Robert
