View Full Version : Bizhub C550 wich cant see finisher.
ReoNeo
04-07-2010, 01:08 PM
Hello... Have a quistion regarding Bizhub C550.
The problem is that the C550 cant see that a finisher Fs-517 is attached.
Hope that someone can give me a hint regarding this issue.
emujo
04-07-2010, 03:50 PM
The FS-517 is not recognized by the copier.
Description:
FS-517 finisher is not recognized.
Solution:
CAUSE: Outdated firmware. Firmware version 6B or higher is required to support the FS-517 or DIPSW 1 & 2 are set to OFF.
SOLUTION: Upgrade the copier firmware to version 6B or higher. Also make sure DIPSW 1 and 2 on the TRCB is set to ON.
Emujo
MR CLEAN OC
04-14-2010, 07:44 AM
bad dc power supply.
ReoNeo
05-19-2010, 07:50 PM
Thank you, changed the power and ok.
