View Full Version : fs 604 with bizhub 750
stathistec
04-14-2010, 04:14 PM
hello
i have a bizhub 750 and fs 604 from bizhub 920 is it posible to work together 750 and fs604
thanks in advance
bizhub1
04-14-2010, 04:44 PM
hello
thanks in advance
The bizhub 750 uses finishers FS 504, FS 505 and FS 602
kmercille
08-01-2011, 03:20 PM
Have bizhub 920 machine says check front stapler machine does not staple at all
emujo
08-01-2011, 05:16 PM
If the FS 604 was originaly on the 920 you may want to go through and check the DIP switches for punch settings as they are different. Emujo
MILLER4157
08-02-2011, 04:56 AM
if the message was displaying originally,
did this occur after replacing staples?
swap the cartridge to the rear stapler. does the message change to check rear stapler?
when opening and closing the door if the cartridge is bad, you should hear a clicking as the cartridge is trying to set.
another issue may be the actuator that detects the remaining amount of staples is missing or broken.
hope this helps
