View Full Version : Bizhub 500 Quality issue with picture
Matt25112
04-14-2010, 05:55 PM
I am heading out to the customers machine right now...have in shop machine to bring drum, developer, transfer sep just to trouble shoot. Thinking fixing motor clock timing or something I really don't quite know yet. This is an internal test print #1. It is also doing this when copying.
4058
file:///C:/DOCUME%7E1/matt/LOCALS%7E1/Temp/moz-screenshot.pngfile:///C:/DOCUME%7E1/matt/LOCALS%7E1/Temp/moz-screenshot-1.png
Matt25112
04-14-2010, 08:52 PM
No luck...I have an in shop machine to swap parts with.....any suggestions. I stopped the machine mid print and I can tell you the drum looks good but the image is being put on before the fuser so I am thinking the back end of the print is whipping away from the drum...
RRodgers
04-15-2010, 01:15 AM
Try a thicker piece of paper and see if it does the same thing.
mo0651
04-15-2010, 02:57 PM
How many copies? Need a pm? A little more info might help.
Matt25112
04-15-2010, 03:04 PM
Developer was replaced 93k ago, image on drum looks fine though, I think it is a contact issue with transfer sep. Depending on how easy it is I may take the side door/transfer door or certain parts of it off our machine and pop it on there just to get this thing down to an area. Customer is not in desperate situation as they only see this problem on higher coverage jobs.
Matt25112
04-15-2010, 03:05 PM
Will do with the thicker paper...
BIG PAPA
04-15-2010, 04:05 PM
Had similar issues in the past, cleaning T&S usually took care of it for me. Machines would dump into transfer and effect bias. cleaning wires would resolve. Have you tried a different T&S Unit?
mo0651
04-15-2010, 04:33 PM
Cleaning both trans/sep wires will work in some cases. Check the main charge wire also. Scotch brite all the copper grounding contacts on that door and frame while you are in there!
copytechman
04-15-2010, 08:07 PM
Seconding cleaning xfer unit wires etc, seen that symptom too!.
Regards!
A.
