View Full Version : bizhub c353 won't print from windows 7
KalispellTech
04-22-2010, 01:43 AM
I have a remote client on a Peer to Peer network. His XP and Vista PC's print with no issues. Using the Windows 7 driver downloaded from Konica, his two Windows 7 64bit PC's will send a print signal to the printer which will blink it's data light a couple times and then do nothing. No failed print indication on the PC's, the job has left the print spool, just no completed print or attempt to print on the BizHub. Any ideas?
copytechman
04-22-2010, 01:58 AM
What version firmware is in the machine? If it's too far out of sync then the machine may not print (newer driver / older firmware). Had a c280 do that to me recently.
Regards!
A.
KalispellTech
04-22-2010, 02:10 AM
I'm much more a server admin than a printer tech. I see multible ROM versions, what is it that I'm looking for?
copytechman
04-22-2010, 03:35 AM
Mfp controller primarily, it'll be a 2 character combination.. example follows: A02E0Y0-0100-G00-R5. The last 2 characters are the main version for the mfp board. Major revisions started @ 21 (here in Canada anyway), 62, 78, 88, j8, r5 and r6 (which is the current flavour, but r5 is pretty much identical for the most part)..
Regards!
A.
Mr Spock
04-22-2010, 04:10 AM
job list
job list details
print history and view error job
Darren King
04-22-2010, 02:31 PM
We have had luck using the Vista 64 bit driver when the 7 driver gives us trouble.
Hope this helps
Darren
emujo
04-22-2010, 04:11 PM
Go into admin mode, printer settings and turn on print post script errors, if it is this type of error you will get a printout with the exact error. Also, as Mr Spock posted, from the control panel you can see why the job failed. Could also be a user authentication/account track setting issue if this is enabled. Emujo
BIG PAPA
04-22-2010, 04:33 PM
What does show up in the job list? Are they using account track or user Auth? If that is turned on and not set up in driver machine will receive the job and just delete it, but it will show in job list history.
KalispellTech
04-22-2010, 05:20 PM
MFP Controller A02E0Y0-0100-G10-R5(00)
I'll try the Vista driver and see if it makes a difference
copytechman
04-22-2010, 05:35 PM
Yup thats pretty current, I'd use the vista driver over an xp one, if a vista one is available.. Let us know how u make out!
Regards!
A.
KalispellTech
04-22-2010, 05:36 PM
Tried the Vista driver and it did not print. The PC's can see the printer, access the printer admin console, so I know there is not a network issue. It's in communicating to the software.
copytechman
04-22-2010, 05:40 PM
Is account tracking enabled on the device?
Regards!
A.
KalispellTech
04-22-2010, 05:45 PM
Three cheers for authentication. They do have print authentication turned on. Four numbers later and they are happy campers. Thanks for the clue.
copytechman
04-22-2010, 05:52 PM
Cool, gotta love authentication!
Regards!
A.
