View Full Version : Konica C250 ERROR Code
gjbrady2
05-04-2010, 05:29 AM
I just moved to a new location and my printer is giving me this code C-0208 TEL/FAX
RRodgers
05-04-2010, 05:35 AM
I "think" it's a piece of paper stuck behind one of the drawers. I just had a 0204 today and that's what it was. So check Tray 4 and be sure there is no paper wedged behind it.
gjbrady2
05-04-2010, 05:44 AM
I check that and everything is clear. It tells me Telephone and Fax, it will not let me do anything.
Spidula
05-05-2010, 07:28 PM
Try a trouble reset
Turn off main power > Hold utility/counter button and turn main power back on (keep finger on utility counter button) > trouble reset appears on screen > press trouble reset > turn main power off and then back on.
maciej79
05-05-2010, 08:28 PM
Hello,
here what is it...
C0208 Tray 4 Elevator failure
Paper lifting motion
• When the drawer is slid into the main body and the Device Detection Sensor is activated,
the Lift-up Motor starts rotating to raise the Paper Lifting Plate.
• The paper stack of the drawer pushes up the Pick-up Roller. When the upper limit position
is detected through the action of the actuator, it stops raising the paper lifting plate.
• As paper is consumed during the print cycle and the Pick-up Roller is lowered, the Lift-up
Motor is energized until the Lift-up Upper Sensor is blocked again.
Regards
Maciej
