View Full Version : bizhub250 c5352 error code
bizhub 250 that had a c2557 code. i changed developer and when f8 was preformed came up with a c5352 which says its cooling fan. could not find this fan. manual has it in top half. is fan the problemor something i might have done chamnging dev. any help would be apreciated as i have not worked on this model but a couple times and am not real familiar. did take it apart quite a bit looking for this fan. thank you
fixthecopier
05-07-2010, 11:10 AM
The main fan would be in the right side door behind the transfer/ transport section. Sometimes a small piece of paper can stop it from moving.
Thanks for the help I will try looking there
I have the same problem on a B250 and I have replacd the cooling fan behind the Transfer section and still no result! Does anyone have any other suggestions????
suso73os
10-27-2010, 09:22 AM
According to the manual the problem is the M5 cooling fan motor, there is other fan near it, the M6 cooling fan but the trouble code for it is C5353, and this is the UI cooling fan.
PWB-A is defective. Check ICP3 on it. If it's open then, IC26 on this board is shorted (MTD2003F). I had that twice 2 years ago.
