View Full Version : Panasonic DP4510, e05-11
ebsystem
05-08-2007, 04:37 PM
Getting error e05-11 on Panasonic DP4510. Need diagnostic help no Manual on this. Any help is appreciated.
jeffreyozz
05-08-2007, 07:27 PM
printer engine communication abnormal- check the connections on the pcb.
just a tech
05-11-2007, 01:21 AM
i agree with jeffrey..printer engine communication abnormal..check the connections between the spc and the sc boards..looking at copier from rear--the sc board is in upper left corner behind little panel cover and the spc board will be in lower left area behind the waste toner bottle.. ya may have a spc board that's really dirty due to toner dust .. i'd clean the boards and reseat the connectors for starters.. hope this helps..
crazy_freddo
05-13-2007, 01:59 PM
There was a TI out for this problem in Nov. 2005. Basically what the problem is that the rear fram of the large paper cassette is pinching the wires of a harness at the rear of the machine. If you want a copy of the TI PM me
