View Full Version : Konic 7022 F-46-8
Comrep
05-08-2007, 08:31 PM
I am working on a Konica 7022 that had a F35-3 error code. I reset it in SW switch 3-1:1 I now get a F-46-8 error. Can anyone tell me what it is and how to reset it? Thanks. Scott
replace the thermistors and then reset it.
Comrep
05-09-2007, 02:49 PM
Hi CMB, I had posted on Smarka also on this issue. A tech there says that it is the laser unit. Does the book tell you that this is what the error code means or is it experience that tells you this? Thanks. Scott
sorry i gave you the wrong info the first time.....
Solution ID TAUS0619168EN00 Solution Usage 37
Description
F46-8 at power up.
Solution
CAUSE: Laser index error caused by a failed index sensor board.
SOLUTION: Replace write unit (p/n 26WA-6500).
Comrep
05-10-2007, 02:08 PM
CMB Thanks for your help. I hope I can return the favor in the future. Scott
