View Full Version : problem with dark area in c6500
gang1110
05-10-2010, 07:36 PM
when customer print for exp. coated paper 130gr with dark area it's stack in the fuser unit the problem
is i got small gap in margin can i play with the gap or change somthing in the utility ? in heavy paper
like 200 gr it's not happen thanks
random
05-11-2010, 11:45 AM
If this is on Fiery try 'toner reduction' setting. It is actually better to run a lighter paper weight.
gang1110
05-11-2010, 12:52 PM
it's happen when he use paper lighter the paper stick in the fuser becuse the he print dark background
Sticks to the fuser? Is the client using laser gloss or press gloss? I can't see adjusting fuser pressure as the resolution here. I would try a different brand of paper same wieght, as well I would try different weight settings to see if paper passes at any speed. Last note make sure you run a few blank sheet between jams to clean excess toner.
gang1110
05-11-2010, 02:17 PM
thanks for the information i will try
sbillis
05-11-2010, 09:16 PM
what paper size? If is A4 try A4S (=A4R=A4 rotated 90 degree)
try toner reduction or toner exposure.
You can see also is black is made from CMYK or from pure black. Preffered to made on your file from K only.
Nothing else can help you.
Final solution heavier paper.
gang1110
05-11-2010, 10:36 PM
he use A3 gloss paper i think it's short fiber mybe this is the problem . what is the best way to check if it is short or long fiber in heavy/light paper ?
Herrmann
05-12-2010, 10:20 PM
Fold the paper in half. The
paper will crease easily with the grain. If you fold
against the grain you get a jagged edge.
