View Full Version : Bizhub 600 write unit
fixthecopier
05-14-2010, 01:30 AM
This machine with almost 2,000,000 on it started codeing 4704 and making the copies coming out dark grey all over, almost as dark as the text. I have pulled the write unit and will put it in another 600 tomorrow to test it. Has anyone else had an issue with this code?
aleksander
05-17-2010, 04:13 AM
have you ever try to replace the write unit? or try to check your drum & developing unit.
fixthecopier
05-17-2010, 12:25 PM
The write unit tested fine, then I found that the charge was touching the drum and causing the problem.
emujo
05-17-2010, 01:26 PM
Almost every time I PM one of these, I have to go back into the drum section and pull the charge unit out to fix this problem. It looks fine going back in, but within 200 copies, I am pulling developer, or have CQ issues. Any tips on the correct way of replacing the charge unit so these problems don't pop up? Emujo
