I have a print problem on Minolta Di200f and Di251f, when it turn on it print the network configuration page, but I cannot print to it and I cannot ping the IP, but I connected the network cable directly to the laptop, the ping works without any switch or router, also when i type the Ip address on explorer I get the webpage with alert and when i exit and try again I cannot get to it, any suggestion to resolve the problem, or the network card is bad and what network card is compatible for replacement, and I don't have a service manual if any one can send me a link to look how to resolve it, thank you
Minolta Di200f
copyguy5
Di Print Controller
I beleive that the print controller is the PI-3500. It sounds like the NIC may have lost its composure. Resetting is generally fairly easy. The PI-3500 Service Manual is at:
I usually try to reset the NIC first.
Since you indicated that you can open a browser to the IP address, open a DOS window, telnet 192.xxx.xxx.xxx
default User is "sysadm" Default Passwd is "sysadm"
verify settings. I always reset to default values and then start over.
this is easier that going thru the Strap to Refresh Boot procedure.
Godd Luck
copyguy5 -
sagebrother
Di200 uses a Pi3502... make sure that the port configuration is set to lpr and the que name is PORT1...Comment
manuellois
i have a similar problem
I have a similar problem, my machine is a minolta di315f ,i reset the network card configuration , and then change network configuration, so now i can print from my computers but when i turn on the machine, it always print the network configuration page.
what can i do to stop printing the network configuration page?
thank you.Comment
DI200/251/351 use PI3502 print controllers;
PI3502 have compatibility issues,
we must use the old HUB or ROUTER!
PI3502 always print the network configuration page.
The need for a specialized software to turn off, In the DOS window!!!Comment
