View Full Version : Dead Machine Konica Minolta bizhub 252 is not loaded to the system at startup
LinART
05-25-2010, 01:02 PM
Konica Minolta bizhub 252 is not loaded to the system at startup. The screen shows a clock, then fades out the screen. I suspect that the problem with NVRAM. Now I want to write the firmware from the CF ... But I can not find it. Anyone can send an e-mail admin@sadmin.org firmware for 252p, for example, 4038-F000-G00-K0-300_CHECKSUM-6452 (Phase 3.05)? Or NVRAM recovery firmware bizhub C250/C252: 20070301_4038-F000-GCN-G4-000 (2000), Checksum: 16E6.EXE. Thank you.
RRodgers
05-25-2010, 01:08 PM
Try a trouble reset first. Turn the machine on while holding down the Utility key.
LinART
05-25-2010, 01:16 PM
It did not help.
xsstaff
06-22-2010, 05:11 PM
hi there! please tell me if you managed the situation... i'm in the same position, and i can't find the nvram recovery for bizhub c252. if you need, i have the firmware you requested. thanks!
LinART
06-22-2010, 05:37 PM
I solved the problem with NVRAM recovery firmware bizhub C250/C252. I can share. Contact with PM
radew
07-05-2010, 03:20 AM
Dear All,
I also have the similar problem and been trying to program the copier without any success despite with the technician from the local copier company ..
I will be grateful if someone could give me a pointer ?
Cheers,
Mao
Naveed Shahid
10-04-2012, 11:53 AM
can u send me solution i am also facing same problem
thanks
naveed
toshiba_estudio@yahoo.com
ozkan
05-26-2018, 11:48 AM
Hi I have the same problem, but I couldn't find the firmware. Any suggestions?
