View Full Version : KM c450 error code c2257
chriscctx
05-26-2010, 05:44 PM
Konica Minolta Bizhub C450
getting an error code of c2257
Can someone tell me what that is and how to fix.
KM GUY
05-26-2010, 10:29 PM
A 2257 could mean that your tranfer belt cleaning assembly is bound up with toner or a gear is damaged, pull transfer belt assembly and turn cleaning unit gears by hand
iconzap
05-26-2010, 10:44 PM
c2257 in the lower model c250 is low toner. try to put a new toner and replenish toner.
chriscctx
05-27-2010, 04:41 PM
thanks KM Guy - I pulled the transfer unit out and there is a problem with that gear. I switched transfer belts with another unit and it fixed the problem on that machine and caused
the same problem on the unit I put that transfer belt in. The gear on that transfer belt is bent like. Don't know what caused that. But thanks for pointing me in the right direction.
Jonzeboy
05-28-2010, 01:04 PM
It's sometimes caused when the customer replace the toner waste box and dont insert it properly...
