View Full Version : Konica bh 7145 f51-2
copierlady
05-28-2010, 05:11 PM
Working in a konica biz hub 7145 keeps jamming (j30-0). Finally gave me a f51-2 code and i changed the fixing driver motor. But it is still jamming (j30-0) and occationally giving be a f51-2 code. Any ideas out there?
Techace
05-30-2010, 11:21 PM
hi,
this code for main motor speed problem, try to change the main motor or open the back cover and check any abnormality.
regards
Techace,
RRodgers
05-31-2010, 04:41 AM
I just had this on a 7040. Turned out to be the dev drive bushing get gummed up and drag down the motor. It's easy to pull the dev drive out and clean/lube those up.
copierlady
05-31-2010, 04:34 PM
Ok guys that gives me a direction to go. Why did i think it had something to do with the fixing drive motor? Got off track somehow. Do you have a part number for that motor? Don't want to replace the wrong one again! Thanks for the help.
RRodgers
05-31-2010, 07:57 PM
If the motor is NOT spinning its the motor if its turning its the bushings.
copierlady
05-31-2010, 09:15 PM
Thanks! Why are we on here?
We are supose to be relaxing and regenerating!
