View Full Version : Miscellaneous back to back registration issue in km6501
minolta
06-04-2010, 12:50 PM
how to set back to back registration ?
kindly help me. i am in big trouble
sbillis
06-05-2010, 09:03 PM
what do you mean back to back registration?
front side with back side?
minolta
06-07-2010, 11:26 AM
yes.front side & back side image shoud co-inside.
I have a problem in leading edge to trailing edge direction
sbillis
06-07-2010, 07:19 PM
did you try image shift from driver?
your problem appears on all prints or is losing leading and trailing edge during printout? ex 15th,16th and then is ok?
I believe this is an issue that has a lot of discussion.
fernan
06-07-2010, 07:38 PM
i agree about it,it will indeed need a lot of discussion,
minolta
06-08-2010, 10:50 AM
ok ,thank you
i will try with image shifting option.
before that i did the restart timing & centering adjustment.that is not helped me
sbillis
06-08-2010, 07:28 PM
Restart timin, Centering, FD and CD adjust for the tray you want.
What is your paper? Is auto duplexing?
It does also matter if is manual duplex the way you turn around the paper...
Check FD and CD first.
minolta
06-09-2010, 02:05 PM
i cheked CD ,FD &Restart timing. It was ok .everthing i set as service mannual.
for examble if print a job in 13x19 size , 250gsm , bypass or LU,Sigle side .
if i measure non printable area in all the four sides,
right side & left side measurement is ok (ex:7mm on both sides)
leading edge &trailing edge measurement is not ok (ex:lead-7mm, trailing -9mm)
That means image is not centering on front side.
because of this back side image also not center.
papersize is exact 13x19 only.
Albonline
06-09-2010, 02:38 PM
the allowable error in feed timeing on that model is 2mm per side on 11x17, thus you could see up to 4+ mm of feed timeing error on a 2 sided 13x19 print.
sbillis
06-09-2010, 05:17 PM
what size your image have? is 13x19, 12x18 or another custom size?
scale 100% or fit to page?
I think the best solution for that is to play with image shift.
Also keep in mind that if you have 0,5% deviation on long size you are ok.
as you see is a matter with a lot of parameters and is endless.
