copytechman
06-04-2010, 06:09 PM
Hello all, recently I had to t-shoot a noisy C280, it was squawking whenever the fuser pressure mechanism engaged/disengaged.. @ the time I thought it was the fuser since this was one of the first ones we'd set up.. Long story short, replaced fuser, noise remained, found an issue (and later a bulletin) about the fuser pressure drive motor mounting causing noise.. Well that fixed the machine but now I have a fuser thats good but not in it's "new" state. I tried checking everywhere I could on all of the harnesses into the fuser but couldn't find the telltale little green fuse (like on the older c353 series and earlier). Does anyone know a) if this fuser has a reset fuse, and b) where the h*ck is it? Cuz I tried and I couldn't find it anywhere!!
Best Regards!
A.
Ps this also apply to some colour OKI fusers too... same issue.. couldnt find the fuse.. (on those machines the schematic for the fuse even tells u where it is!! ) No dice.. @ least not per the manual!!
Best Regards!
A.
