View Full Version : C2557
CCS@yahoo
06-04-2010, 07:50 PM
Konica Minolta Bizhub 200 - code "C2557" and how do I access counters
CCS@yahoo
06-04-2010, 08:13 PM
c2557 - ATDC MALFUNCT. S0,S1 oooooooo end
fishleg
06-05-2010, 08:50 AM
leave the door open :). The way I always dev these 1. Do the unit replace drum dev 2. Open side door 3. reset counters in service mode 4. go into f8 instant you shut the door press start you may have to exit f8 then go into it again after shutting door. Any other way seems to end in disaster with these machines btw 250 sucks balls unit doesnt last 5 minutes.
hussain
06-05-2010, 08:58 AM
refer service manual, that will tell you the type of error code
fixthecopier
06-05-2010, 12:16 PM
If you do not know where he counters are, you will have a hard time with the drum and developer. If you are a tech for different brand, get a manual. That code can come from someone resetting the counter prematurely. Machine will run forever if you know what you are doing.
