View Full Version : sharp AR-M451N
adel_nagieb2000@yahoo.com
06-05-2010, 08:39 AM
i have error in sharp ar-m451 u2-22 and make a program 16 it remove this error and the machine work
good after turn off the machine about one hour then turn on the error u2-22 back to the machine
some one help me
OMD-227
06-05-2010, 02:01 PM
MCU battery jumper setting error. Make sure JP6 is set to ON, or you have a flat battery, or a damage battery connection. Ensure battery is making proper contact.
DINGO
06-05-2010, 07:44 PM
Well regarded by the master WAZZA, U2-22 was around that causes, and more dificult to identify because itīs one code that dīont come listed in service manual, (at least i' m in portugal) thanks wazza.
If that dīont fix your problem, think if you do something, like change icu flash, firmware, and so, or
disassemble and assemble boards, and chek if the jumper that wazza said, if is in the correct position chek if it have a good continuity.
have a good day and good look.
OMD-227
06-06-2010, 12:46 PM
Thank you for the email Adel. I'm happy your problem is solved.
