View Full Version : Bizhub 600, anoying customer after copying from glass.
fixthecopier
06-05-2010, 01:17 PM
I have not gone to see the machine yet, but the customer says that if he puts a small original on the glass and makes a copy, then removes it and try to make a normal size copy, the machine ask for 8 and half by 5 and half, even if you press panel reset , unless you lift the lid and close it a second time. None of his other Bizhub 600s do it so he wants it fixed, and he is the manager for a 325 machine contract. Has any one else seen this.
randall
06-05-2010, 02:26 PM
under the user settings>copier settings> "Auto paper size for small original" turn it off or set for 8.5 x 11
fixthecopier
06-19-2010, 03:50 PM
In an effort to help someone in the future, I wanted to close this. The problem was the plunger and actuator that the doc feed depresses when you close it. I do not know why, I removed the assembly and checked it, and after I reinstalled it it began working correctly. I found it was the plunger assembly by noticing that when I lowered the lid slowly, I had no problem. Hope this helps.
