connecticcut
06-06-2010, 01:53 PM
to avoid stumbling jams with the paper thick3 10pts, install a Feed Ricoh copier on minolta copier (first drawer).
I take cahoutchouc a feed (first drawer Ricoh 1224C). After removing (cutting it) big cahoutchouc minolta, I slide on the hub minolta feed Ricoh (easy to install after having doused with alcohol ). It is a little longer than the minolta but this does not alter the deranged operation.
Your customers will thank you and will be able to use the thick3 without apprehension (to print the business card ).
