View Full Version : C6501
gamalmehdar
06-13-2010, 11:05 AM
the machine give the error C1541 .
i disconnect all the finishers but still the error?
how can reset this error???
thanks for all:cool:
sbillis
06-16-2010, 11:10 PM
what the error tells you do check?
JustManuals
06-17-2010, 12:50 AM
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals (http://www.justmanuals.com)
Paul@justmanuals.com
Stirton.M
06-17-2010, 01:52 AM
Ignore the manuals4you spammer, his manuals are out of date. You should be able to download them via Konica Minolta Tech Support.
The error relates to the perfect binder option of the finisher. If you are getting this error without the finisher connected, then the printer control board (PRCB) might be at fault and it is there you should look further, either by checking the connectors on the board and reseating all of them or replace the board itself if all else fails.
C-1541
After the warm-up is started, temperature detected by the glue tank temperature sensor / Lw (TH4) has not risen to a prescribed level within a specified time period.
Places to check.
AC drive board (ACDB)
Glue tank heater (H1)
Glue apply roller heater (H2)
PB control board (PBCB)
PB drive board (PBDB)
Glue apply roller motor (M32)
Glue tank temperature sensor /Lw (TH4)
Software switch 7-7 can be switched from 0 to 1 to disable the perfect bind feature as a troubleshooting measure.
gamalmehdar
06-22-2010, 06:23 AM
thanks for all
yes that is the software switch its the problem
now its ok
