View Full Version : BIZHUB C220
thuo
06-14-2010, 12:37 PM
Blurred images when copying after replacing scanner unit in bizhub c220.
please assist
BIG PAPA
06-14-2010, 01:04 PM
What exactly did you replace? The CCD, Mirrors, Glass, or the whole thing? Hate to point out the obviuos, but it is probably something you did.
Stirton.M
06-15-2010, 04:42 AM
I agree with Big Pappa.
Follow the service manual regarding the replacement of this. You likely overlooked a very important step.
thuo
06-15-2010, 04:03 PM
I changed the lamp and the ccd. followed the manual to the letter but the copies are still blurred.
Stirton.M
06-16-2010, 12:43 AM
Might seem like a dumb answer, but clean the lens???
Any other adjustment is not recommended, but you may have to adjust the focal length of where the CCD sits. I would defer to tech support with KM on this matter.
Gergő
02-07-2011, 10:54 AM
Hello
Can I ask, why did you change the CCD?
I have problem, with the colors. Printed pictures are fine, but in copy function the eveything is more green than it should be.
SmellsHot
02-07-2011, 01:19 PM
Make sure the CCD is seated properly, all screws are tigthened and it's aligned correctly
Chip Resets SA
02-08-2011, 05:27 PM
Did you put all the screws you took out back in the same order? I've had it where one screw was too long and just that mm or two blurred the whole image! Don't know if it's that same on the C220 but worth a try!
emujo
02-08-2011, 07:56 PM
Had one of the black plastic sliders the lamp assy moves on pop out, caused the x lamp/1st mirror assy to be slightly skewed, wasn't through ADF, but scans from platen were way out of whack. Emujo
eg101
02-08-2011, 09:43 PM
Is everything you run blurred or just copies from the glass?
