COMPATIBILITY
  • CCS@yahoo
    • Mar 2009
    • 14
    COMPATIBILITY
    Being similiar in design and operation - would di251/351 starter work in a biz 250/350 ?who may know this ? *tanx !
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Short answer.
    NO.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • ck1
      • 485
      Originally posted by Stirton.M
      Short answer.
      NO.
      yes you are right , but any have try change the atdc sensor for di to bz tank and try ?
      • DadO
        • Dec 2007
        • 401
        no offense to all but I added starter from bizhub 162/163 to it and works
        • Rudi
          • Jun 2007
          • 251
          How did you do that because i tried putting dv110 in a b250 ,didnt work , i tried putting dv310 in a di3510 , didnt work , i tried the same with the toners , didnt work. So if you know the secret to doing that please let me know because that will save me alot of stress when it comes to parts availability.They use the same drum so logic tells me they should use the same developer except the dv310 is slightly more in a packet than the dv 110 so that goes back to atdc or maybe softswitches and that is maybe why the 3510 dev unit lasts 4 times longer than the B250.
          • tonerspot
            • Nov 2008
            • 79
            dv 110 work on di2510 and b250/350
            • CCS@yahoo
              • Mar 2009
              • 14
              it seems like many minoltas of days gone by - the only difference in starter was in gram quanity and drum type (cadmium, selinium, organic, digital) The inline resistor of theATDC for the Biz and DI are of different values. A 1/2 copy is produced before c2557 , the C.Q. is of that copy is excellent. I know I need a 100 more grs. for .Biz and maybe I'll try DI ATDC in Biz - see what happens. - compatibility improves availibility most definetly. Thanks for the feedback/knowledge.
              • Hansoon
                • Sep 2007
                • 3350
                Only thing I know is that when you use an ATDC sensor from a Di-3510 for a Bizhub it codes out with C-2557 for sure.....
                The whole ImageUnit/Drum/Developer issue with the Bizhub 350 is so critical that I prefer to use only the intended developer (starter). Aftermarket drum cores and toner however work well.
                Hans
                “ Sent from my Intel 80286 using MS-DOS 2.0
                https://www.copytechnet.com/images/smilies/biggrin.png
                • ck1
                  • 485
                  are you sure friend ????
                  • tonerspot
                    • Nov 2008
                    • 79
                    yes i am sure
                    • minimerlin
                      • 851
                      Look at the atdc % settings for the bh250/350 ...7%. The di2510 it is 14%!! I think these devs are not the same at all, I have put DV110 in a BH250 and it always codes out!
                      Please do not PM me without asking first.
                      • ck1
                        • 485
                        me too , change the atdc can or not ?
