View Full Version : firmware upgrade bizhub C203
aleksander
06-17-2010, 02:38 AM
I tried to upgrade the firmware bizhub C203 to the latest version. I used compact flash to upgrade but Failed. Message "Invalid card" appear. I've already formatted the CF using software Firmware Imaging Toolkit from KM and following the instruction from Service manual. I tried CF 1 GB and 128 MB and Failed.
Anyone know the solution? please help me.
Thank you.
rprem
06-17-2010, 10:03 AM
have u check the card try a new 128 mb card and install firmware with imaging tool kit
emujo
06-17-2010, 02:07 PM
You need to get a new, unformatted CF card. 128 mb. Once you use this card, never, never,never use it for a B&W MFP again. You can flash the card for 203 through C650 over and over but once you put B&W firmware on it it will never work in a color MFP again. My vendor recommendation is the Transcend 128mb Industrial. Emujo
The problem has to do with the speed of the CF card. It shouldn't be quicker than x40. I have tried 128mb x80 and it didn't work. A 512mb x40 should be no problem.
Stirton.M
06-17-2010, 11:29 PM
There are an assortment of issues regarding CF card programming, as illustrated by the others.
Some cards work flawlessly, while others simply fail no matter what you do. It's a crap shoot where brand is concerned as well. In some situations, formatting the card with vxworks will help, while others this does nothing.
You could try buying a flash card from KM for the model you need, though this is a bit impractical because of the cost of the card relative to what you would spend at an electronics store. But for piece of mind knowing this card will work vs that of the trying multiple brands. The other issue of course, is finding the right memory size. Most literature I've read indicates 128MB as a minimum, 256 as a maximum, limiting availability on the open market.
aleksander
06-18-2010, 08:37 AM
I did it but still failed.
aleksander
06-18-2010, 08:48 AM
So the point is, I need to buy a new CF card 128 / 256 MB?
It so hard to find CF 128 / 256 in my country.
Stirton.M
06-18-2010, 02:50 PM
It's the same issue here, cards of these sizes are a rarity. They can be found, but not without much searching about. We eventually ended up ordering some online and trying that.
Crucial 256 has worked for us, so you should have some luck with those if you can find some. Just make sure they are not used cards, as they may have been formatted, which you obviously do not want and will just put you back where you are now, with a useless card.
aleksander
06-21-2010, 04:53 AM
OK, thank you all for your answer. I'll try to find a new CF card28 / 256 MB. I hope it works for my C203 and C353. So complicated issue. :)
rprem
06-21-2010, 06:42 AM
you can find 128 mb flash card in ebay site
Stirton.M
06-21-2010, 11:57 PM
There's no guarantee the cards on Ebay are unused, or for that matter, compatible. Not to mention they are more often than not, overpriced because of the bidding nonesense that Ebay is. Personally, I'd rather drive a fork in my brain than trust Ebay for something that is critical like a card that must work.
rprem
06-22-2010, 05:40 AM
you can find used as well as new flash card in ebay site it cost around rs 500 i bought it from there only its working fine
vishnu1125
08-03-2015, 12:44 PM
from weree we get 128mb new cf card?
vishnu1125
08-03-2015, 12:53 PM
hi can you pls give ur 128mb cf card for me to update our firmware,iam frm kerala pls help me..
mob:9809749788(i can pay)
