View Full Version : Bizhub C203 appears C255C
Wasfil
06-17-2010, 10:45 AM
I have aproblem with C203 MFP, when i replaced an Imaging Unit Black, C255C monitor appears, this indicator refer to TCR adjustment IU Black Failure, so i change with new one, but aproblem is still appears this code. I try to used this IU to the other machine, the result is same problem occur to the other machine. help me ..Thx:o
copytechman
06-17-2010, 12:00 PM
Try (gently) shaking iu side to side then try again. Otherwise replace imaging unit, u may have a dud.
Regards!
A.
Jumping Jack Flash
06-17-2010, 02:45 PM
My suggestions are:
1st Install the chip in the old module with the new BK IU and turn on the machine several times.
2nd If the chip with the launch of a new module in the old UI that means that the machinery put the correct value of the TCR.
3rd You can now unlock the chip with the correct value to insert into the new UI.
4th If this fails, use the device to enter the correct value to the TCR to the chip from the new module.
Please View
49984999
