View Full Version : Konica Minolta C500 SC-89-01
johva
06-23-2010, 03:14 PM
I bought a Konica Minolta C500 without the external Fiery. I have a parts C500 with an internal print controller and installed it into the New C500. I get a SC-89-01 error code. I tried the change board command and it did not help. Maybe I'm doing something wrong or do I have to upgrade the firmware. Please advise. Thanks, Johva.
costel fasola
06-23-2010, 04:45 PM
"SC89-xx after replacing a PWB (Overall Control, Printer Control, or Operation PWB).
Solution
CAUSE: The machine serial number needs to be programmed using the Board Change Mode.
SOLUTION: To program the machine serial number, perform the following:
1. Flash the status CB (main CB), printer CB or operation board to the latest firmware level prior to performing the Board Change Mode.
2. Access the 25 mode (power machine OFF/ON while pressing the 2 and 5 keys).
3. Select Board Change Mode.
4. Select the board that was changed (operation, overall CB, NVRAM, printer CB).
5. Press OK.
6. Enter the machine serial number using the alphanumeric key pad on the touchscreen.
7. .Press OK.
8. Power the machine OFF/ON.
ERROR CODE EXPLANATION
- SC89-01
This code is caused by incompatibility between the replaced PRDB assigned S/N and mainbody S/N. For example, when trying to install the PRDB which was
removed from Machine A to Machine B main body.
- SC89-03
This code is caused by performing Board Change Mode with a used PRDB. For example, when trying to install the PRDB which was removed from Machine A
to Machine B main body and perform Board Change Mode.
IMPORTANT :As a troubleshooting 'tool', a new or used Printer CB, Overall CB, or Operation Board can be temporarily installed in theMFP for testing
purposes without using Board Change Mode.
Notes :
1. The number of boards that can be replaced at one time is restricted to two. Boards must be new, swapping between machines is prohibited.
2. Please refer to attached documentation for additional detail. To view a PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for
free from the Adobe® web site at: Adobe - Adobe Reader download - All versions (http://www.adobe.com/products/acrobat/readstep2.html) .
SPECIAL NOTE : Solution contribution by Cesar Jimenez, Production Print/SSD"
sow dear friend,
if u try a change boards into another machines is not work one by one. i try this. Boards must be new, swapping between machines is prohibited.
now i try change all 4 board into another mashines A to B. all controller and PRCB in the same machine. maybe work this way.if is work i let u know .
johva
06-23-2010, 07:32 PM
Thank you for your help. I'll give it a try.
Johva
costel fasola
06-27-2010, 07:27 PM
Solution
5. Press OK.
7. .Press OK.
- SC89-01
- SC89-03
Notes :
sow dear friend,
is working my friend, if u change all boards in working
rasoul_M
07-29-2010, 04:06 PM
Hello
I have a konika minolta bizhub pro c500 protected with password and I can't change IP settings to put it on my network and using printer.
How can I reset password?
Stirton.M
07-29-2010, 11:45 PM
The password for the fiery is usually default "Fiery.1" (upper case F, no quotes).
If that does not work, let me know, there is a file you can push to the fiery to make it print out the current password set.
jzheld
09-14-2010, 10:18 PM
just want to make everything clear, I'm new to the konica and I need to change the board from one to another, both used, basically new one machine work out out of 2, I just plugged the bord that I'm sure was working to another machine and got 89-01, in the service mode the is an option to change the board but it's asking for the main body numer and I have no idea where is it. Thanks in advance
jma676
09-14-2010, 11:47 PM
Konica Minolta Bizhub Pro C500 Error Code E-8901
Just try to learn properly before you do anything, you should be sure to make the replacements correctly.
This was said before read carefully the response of Costel (# 2) in this thread.
Must follow the steps to change board.
Code = E89-01
Cause = This code is caused by incompatibility between the replaced PRDB assigned S/N in mainbody with other S/N.
*For example, when trying to install the PRDB which was removed from 000000001 to 000000005 main body.
Note: Board change mode=
When changing any of the following four types of
boards, be sure to set the serial number of the main
body in this setting.
• OPERATION (operation board /1).
• OVERALL CB (overall control board).
• NVRAM (memory board).
• PRINTER (printer control board).
Procedure
1. Enter the 25 mode.
2. "25 mode menu screen" Press the [13. Board change mode] key.
3. "Board change mode screen" Select a key of the board that you have replaced a part.
4. "Serial number input screen" Enter the serial number of the main body through the alphanumeric keys.
5. Press the [OK] key to update the data.
To invalidate the setting that you have changed, press the [CANCEL] key.
And..............: The number of boards that can be replaced at the same time is restricted only to two boards.
jzheld
09-15-2010, 02:45 PM
that's where I get stucked, can you tall me where is main body serial number? I found one, but it keeps saying "please enter rightly"
jma676
09-15-2010, 03:10 PM
Press Key [P (COUNTER)] on the control panel.
jzheld
09-15-2010, 03:13 PM
but how I'm in 25 mode otherwise error 89-01
jma676
09-15-2010, 03:27 PM
Serial Number in 25 Mode
M/C serial number setting
Display and set the serial numbers of the main body
and options
2. "25 mode menu screen" Press the [8. M/C serial number setting] key.
3. do not change anything... just Display.
Note:
• The serial number of the main body cannot be changed.
Or Check: Counter list Print, Managment List, Mainbody...
jzheld
09-15-2010, 03:35 PM
Thank you
HUYNHTUONG
11-19-2016, 08:54 AM
I follow your instructions. and discovered errors SC89-02. Would you guide me how to resolve this error code. The next step how to do.
Reasons "I replaced a OACB main board from one machine to another. SC89-01 error detection. Follow the instructions from you, SC89-02 error detection". looking forward to your help.
Procedure
And..............: The number of boards that can be replaced at the same time is restricted only to two boards.[/QUOTE]
jma676
11-22-2016, 02:39 PM
Procedure
Hello, those instructions are not mine, they are from Bulletins or Service Manuals. (It is advisable to follow the thread of the post to know that each answer corresponds to the previous one.).
That is de last KM Guide to this error.
Solution ID TAUS0640895EN*
Description
SC89-xx after replacing the status (main CB) board, operation board, printer CB or NVRAM.
5. Press OK.
7. .Press OK.
- SC89-01
This code is caused by incompatibility between the replaced PRDB assigned S/N and mainbody S/N. For example, when trying to install the PRDB which was removed from 65AE00001 to 65AE00005 main body.
- SC89-03
65AE00001 to 65AE00005 main body and perform Board Change Mode.
IMPORTANT: As a troubleshooting 'tool', a new or used Printer CB, Overall CB, or Operation Board can be temporarily installed in the 8050 for testing purposes without using Board Change Mode.
Notes:
* The number of boards that can be replaced at one time is restricted to two. Boards must be new, swapping between machines is prohibited.
Trademark ownership information Copyright 2010, Konica Minolta Business Solutions U.S.A., Inc.
My Note: Bulletins error: PRDB is wrong. I think is refer to PRCB ("PR" Printer "CB" Control Board)
