View Full Version : white spot on c552 !!!!
gang1110
06-24-2010, 10:21 PM
customer complain sometimes there is like white spot on part of the paper print i try to clean the transfer
belt and roller transfer and make stabilizer and gradiation it's not help it's heppend even on paer a3 80gr
the machine count is 50000 almost new the consumbel's image's and belt look good 20% life ?
attached example . please i need quick answer thank's
mo0651
06-24-2010, 10:28 PM
Try a solid black copy. Your picture shows black is real weak. I think
mo0651
06-24-2010, 10:30 PM
are these 8.5 x 11 single sided copies? does it repeat on 1 copy? consecutive copies?
gang1110
06-24-2010, 10:36 PM
yes it's single side copy it's not repeat on every copy but when i print from the test pattern it's shows almost on every color in the same place
rprem
06-25-2010, 06:25 AM
check the belt i
mo0651
06-25-2010, 02:15 PM
I'd pull the transfer belt and look it over. could be a crack starting.
gang1110
06-25-2010, 10:09 PM
i pull the transfer belt and clean the belt with alcohol nothing change mybey try to play with the voltage of first and second transfer ?
minimerlin
06-25-2010, 10:37 PM
I agree with rprem, looks like a belt problem. Are you sure there is not a ding in it?
rprem
06-26-2010, 07:28 AM
if u have another machine u just interchange the belt and check it out
