View Full Version : 1820 not feeding from bypass
tommygun
06-25-2010, 02:11 AM
i have an 1820 where the solenoid that releases the paper feed clutch is not acitivating after the first page is through, it works once than decides not to, i have to take out the duplex guide reset everything and than it happens all over again, any help would be welcomed because i am stumped, thanks.
suckis
07-04-2010, 08:56 AM
I had several problems with 1520/1820s' bypasses. Most of them had to do with the bypass feed clutch (the spring inside the clutch was faulty).
etsmultan
07-10-2010, 01:24 PM
replace the spring inside the clutch,it is faulty
tommygun
07-13-2010, 05:19 AM
thanks guys it worked i ordered one ages ago and only just recieved it
suckis
07-13-2010, 08:42 AM
:) Thank you foro your reply tommygun.
