Just arrived from vacation... we have ineo250 here inside the workshop, i still don't have enough time to check it, just want to know if you encountered the same trouble... it shows jam on duplex unit but there is no paper jam and no problem on the said unit. The other technician already confirmed that the unit is okay together with the main board from the other working good machine. The wondering part in here is, if you disconnect the connector of the duplex unit the machine is working perfect! Cables, connectors, duplex unit and main board were already swapped but the same problem exist! Guys, any experienced with this problem?
ineo250 without duplex ok
