The copied image is skewed about 30 degrees. This copier has 391K copies on it. Six months ago at 368K copies, it had the SAME issue. At that time, I replaced the A/D converter board to no avail, then I replaced the Write unit and the problem appeared to be solved. The image was perfect. Yesterday, the copier had a J-32 error code. After I corrected a sticking flag at PS25, upon power up, it had an F28-1 error code!!! Today, I replaced HV1 and that didn't change the F28-1 code. I cleaned the corona assembly and the machine came up and functions, but now this skewing problem is back again, LIKE HERPES!! Any advice will be cherished. Thanks in advance.![Confused](http://www.copytechnet.com/forums/images/smilies/confused.png)
