View Full Version : Konica 7020 will not transmit fax
copierlady
06-30-2010, 11:24 PM
I have a cutomer with a konica 7020 fax/ print. Fax stopped transmitting. It recieves fine but will not transmit. Put a differant fax unit in the machine and still have the same problem. Put their fax unit in a differant machine and it works fine. One solutions says to initilize the memory. But is that memory inside the fax unit itself? If so i don't see how that could help since the fax unit works fine in another machine. Any ideas?
RRodgers
07-01-2010, 01:10 AM
Make sure it's set for US and NOT JP.
copierlady
07-01-2010, 02:07 PM
Going back today. I'll ck. But, it was working fine for a while and then just quit.
mrwho
07-01-2010, 11:27 PM
Yes, check the communication configuration. If the customer has a PBX, it could have been reconfigured or swapped for a new one and that might have changed the requirements - I once had a customer whose PBX required pulse dialing. Later on, when he upgraded the PBX, we had to change the configuration to tone dialing. Also check if you've got a working connection to the outside - try to plug in a phone and make a call somewhere.
JustManuals
07-01-2010, 11:41 PM
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals (http://www.justmanuals.com)
Paul@justmanuals.com
RRodgers
07-02-2010, 03:25 AM
I'm wondering what promted this post?
