View Full Version : Bizhub 920 IC203 SC49-01
dogsbody
07-05-2010, 01:16 PM
I have only one 920 which makes me a bit light on for experience. At the minute it is giving SC49-01, I have tried formatting and then replacing the HDD and updating firmware. When I try to format the hard disk the machine tells me it formatting and sits there, I waited a half hour before I reset the machine, also I tried updating firmware (currently v.20) however when I push START on the panel it doesn't respond and the laptop times out. If anyone has any ideas it would be great if you could share them.
Cheers.
dogsbody
07-12-2010, 10:28 AM
Replaced hardisk
Downloaded the file 'ic203_p121c.exe' from DLBT0703279EN00.
Removed the CF card from the IC-203 and deleted all files (NOT FORMATED).
Copied the files to the card.
Booted into Service Mode and formated HDD.
Now works.
Jccopy85
03-29-2022, 09:27 PM
would you be so kind to help me with the file for ic-203, I have the same code and I haven't been able to solve it
Synthohol
03-29-2022, 10:01 PM
Intermittent SC49-01 and/or SC49-04 codes.
Solution
PROBABLE CAUSES:
1. The hard drive has failed.
Re-flash the IC-203 firmware.Replace the hard drive as needed (p/n 56UAM72000).
Note : The latest version firmware or system software is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support
(CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
2. The IC-203 HDD needs to be formatted.
Format the IC-203 HDD by performing the following:
a.Enter Tech Rep Mode.
b.Press IP Hard Disk Format.
c.Press IP HDD Format.
d.Select ALL and Yes to format.
Note : If the machine will not enter Tech Rep Mode, power OFF the machine and power ON while holding the Utility key.
Jccopy85
03-29-2022, 11:29 PM
Solution
PROBABLE CAUSES:
Excuse me, my English is bad, but is this downloaded from the same machine in the expert settings or from the web?
