View Full Version : Bizhub C250 double imaging
Timothy
07-06-2010, 04:01 AM
I have a Bizhub C250 that has been doulble imaging down the page and it does it in all colors. I replaced the fuser assembly and that worked for two days and now it is back and worse than before. I increadsed the fuser temp by 5 for both the hot and pressure roller and it still has not made a difference. I am kind of at a loss at this one. I have inspected the transfer belt and all of the drums and do not see a problem.
Any help out there?
Stirton.M
07-06-2010, 05:21 AM
Do you have the fuser in envelope mode?
Check the green tabs on the front and rear sides, make sure they are up and not down.
PeterG
07-06-2010, 07:22 AM
Someone is going to be embarrassed over that one.
copytechman
07-06-2010, 12:37 PM
Also check your 2nd transfer roller. I've seen the newer series (c203-353) have those fail and produce symptoms that look pretty much the same as a failed fuser. Led me down the garden path too. Had 1 case of it with a c250 iirc.
Regards!
A.
Timothy
07-07-2010, 05:04 AM
Ok I am embarrased the fuser was in envelope mode and I will admit that I missed that in my haste to repair this machine. The original problem was not fusing on one side and it was not in envelope mode so I didn't even look at that. Thanks for your help.
PeterG
07-07-2010, 07:37 AM
I doubt their is a single one of us that hasn't fallen for that one Timothy.:)
Stirton.M
07-07-2010, 07:50 AM
There are days we are all sleeping at the wheel..... heh
:P
