View Full Version : C3906 bizhub pro 950
aleksander
07-09-2010, 05:00 AM
Hi all,
I have problem with bizhub 950. C3906 shown 3 times a week. the trouble code related with TH 4 and I've already replace it, but still shown. I tried DipSW3 bit 1, it works for 3 days and then the evil code occur again.
Any idea? thank you.
aleksander
07-12-2010, 04:36 AM
Any Idea for C3906 in bizhub pro 950? Please help. Very urgent.
Thank you.
Gergő
07-12-2010, 02:03 PM
CAUSE: Improper ventilation of cooling fan Cooling Fan/1 (FM1).
SOLUTION: Remove the rear cover and run 50 or more sheets of 12x18 paper. If the error does not return, verify that Cooling Fan/1 (p/n 55FA 8052 1) is properly aligned with the hole in the rear cover (p/n A0G6 1612 00).
SPECIAL NOTE: Solution contribution by Gary Scimeca, Production Print/SSD
aleksander
07-13-2010, 04:01 AM
Cooling Fan? no. That's normal. The problem is, C3906 occured at least 3 times a week. C3906 related with TH4 and I already replaced it but the evil code still shown.
Any other solution?
RRodgers
07-13-2010, 02:07 PM
Thank you.
I've seen issue's were the manual says it's the lower heat tube when in FACT it's a problem with the upper heat tube. Be sure to check the other one.
HTH
remati
07-13-2010, 06:56 PM
...the thermistor problems ,are the codes SC36-XX......
remati
07-13-2010, 07:04 PM
...and if the code is the SC36-06
SC36-06 every few days.
CAUSE: Fuser parts require replacement.
SOLUTION: Replace the following parts:
26AA53150 (x2) - heat sleeve
26AA53160 (x2) - bearing
56GAR7100 - cleaning sheet
55VA53070 - auxiliary roller
SPECIAL NOTE: Solution contribution by Jim Frost, Image Business Solutions
aleksander
07-14-2010, 03:43 AM
HTH
RRodgers, could you describe your explanation? I tried to replace TH1, TH2, TH3, TH4 and finally I replace the Fusing Unit. But next day, C3906 occured again. I don't know what's going on with this one.
Thank you RRodgers. I'm waiting for your information. :)
aleksander
07-14-2010, 03:47 AM
I think I wrote C3906 NOT SC3606.
RRodgers
07-14-2010, 04:31 AM
So is it 39 or 36?
aleksander
07-14-2010, 04:39 AM
So is it 39 or 36?
Of course C3906. I've never wrote 36**.
Any solution?
remati
07-14-2010, 09:04 PM
ok ...I`m so sory I looked for the Biz pro 920 manual :(
-C3906 ..if the machine have intermitent codes...
it may have problems with de connector (fuser unit to the machine)or the lamp L3...
aleksander
07-15-2010, 04:42 AM
OK, now working properly. Changing the Fixing Unit, Reset the fusing counter and now it works again. I hope no more C3906 in the future. Thank you guys. :)
