View Full Version : coh jp-5000
gamalmehdar
07-14-2010, 10:55 AM
the problem with this machine is the language in the lcd panel change to japanes after shutdown the machine and stay about 5-10 minutes .
i retern it to english but after shut down its retern again to japanes???
how can resolvethis problem
best regards
craig
07-14-2010, 04:31 PM
I would bet your backup battery on the main board is bad, not keeping your new settings.
gamalmehdar
07-15-2010, 09:49 AM
is the battery inside the eeprom IC .
i didnt get any other battery on the board .
what do you think the pins which shuld be connect the external battery on the IC.
thank you very much
gamalmehdar:confused:
craig
07-15-2010, 04:12 PM
The battery should look like a big watch battery on the main board, not on an IC.
gamalmehdar
07-15-2010, 07:57 PM
in the Ricoh jp-5000 duplecator i think there are no pattery on the board.
but wreten on the eeprom IC
M48T58Y
its with battery.
can you check please
