View Full Version : Di620 Code
copy40
05-29-2007, 07:35 PM
Does anyone know how to reset the maintenance code m6 on a Minolta Di620?? tryed resetting codes in tech mode but still no result:confused:
Bizhub
05-29-2007, 09:20 PM
The message relates to you exposure lamp.
Go into tech rep mode
then go into IR / EDH Check
then go into Function IR
run exposure lamp check
then run address adjust.
Failing that you may need a new exposure lamp.
Good luck
copy40
05-30-2007, 06:18 PM
RESULT!!!!!
thank you, checked optics which are dirty, may not have helped but done as suggested and all ok so far.
Bizhub
05-30-2007, 10:00 PM
Glad to help
If you need any info on any Minolta box I may be able to help.
Also check out NVRAM.BRAVEHOST.COM it's growing all the time and the pop-ups will be gone soon.
It's my hubbies site.
