View Full Version : Bizhub 1050 touch screen isue
Holesaletech27
07-28-2010, 04:23 PM
The touch screen is in-op on this machine. I just read a thread on the C350/C450 with the same issue. I'm going to see if that fix applies to this model as well. Any other suggestions? I could use a part number and price for a replacement as well if anyone has that info...
freixi
07-28-2010, 04:42 PM
What is the problem of the machine?
freixi
Holesaletech27
07-28-2010, 04:58 PM
The touch screen doesn't respond.
freixi
07-28-2010, 05:09 PM
So is a EP 1050? or a bizhub pro 1050?
ineo+6501
07-28-2010, 05:11 PM
Part number for the touch glass: A0G6:M755:00 = Ope.Unit Touch Panel
Your local dealer will be able to price it for you.
From a TAD on CSES:
[Product Name] bizhub PRO 1050
bizhub PRO 1050e
bizhub PRO 1050eP
bizhub PRO 1050P
DEVELOP 1050
generic_1050
[Option]
[Subject] After replacing the NVRAM, the touch panel does not function. [Description]
[Solution]
CAUSE: The touch panel adjustment must be performed.
SOLUTION: Perform the following procedure to perform the touch panel adjustment:
1. Press the [Utility/Counter] key on the control panel.
2. Press the [5] key (hard key) on the control panel to select the "Touch Panel Adjustment".
3. Follow the instructions on the display to perform the adjustment.
SPECIAL NOTE: Solution contribution by Ian Lynch, Production Print/SSD
[Attached Files] [Rev. Memo] Corrected procedure for touch panel adjustment (not in service mode)-irl
[Problem code1] Main body control failure [Problem code2] R06:Main body lock up during operation
ineo+6501
07-28-2010, 05:18 PM
Ooops part number should be: A0G6-M755-00 = Ope.Unit Touch Panel
Holesaletech27
07-28-2010, 05:26 PM
I';s a Bizhub Pro 1050. Thanks for the pointers and info. I'll give it a go and try to get a price.
freixi
07-28-2010, 05:28 PM
Thank ineo. that's it.
