View Full Version : konica1216
cliffhangers
08-02-2010, 09:05 PM
greetings.I am haven problem with konica1216 it's displaying error code P26.please kindly help.thanks in advance.
BIG PAPA
08-02-2010, 10:17 PM
Description:
P26 at power up.
Solution:
CAUSE: The L-detect adjustment procedure was not performed, after resetting the PM counter.
SOLUTION: To perform the L-detect adjustment procedure, perform the following:
1. Power the copier OFF.
2. Access the 47 mode (power the copier ON, while pressing the 4 and 7 keys), output code 51.
3. Press the START/PRINT button.
4. The number 51 flashes in the display for approximately 90 seconds.
5. When the number 51 stops flashing, the adjustment is complete.
6. Power the copier OFF/ON to exit the 47 mode.
cliffhangers
08-03-2010, 08:06 PM
good evening or what ever time you see this.I have perform the L-detect procedure. I access the 47 mode and power the copier on while pressing the 4 and 7 keys,it show code 51 for 10 seconds and change to code F43 i power the copier off and on,it go back to P26 please kindly tell me what to do.thanks in advance.
cliffhangers
08-03-2010, 08:12 PM
