cliffhangers
08-07-2010, 09:33 AM
Hi.with the ink unit it display p26.
i remove the ink unit and power the copier on it still display p26.help.Thanks in advance.
You have to seek for a tech if you cannot solve the problem by yourself.
P26 at power up. SOLUTION ID: 142860
SOLUTION: CAUSE: The L-detect adjustment procedure was not performed, after resetting the PM counter.
SOLUTION: To perform the L-detect adjustment procedure, perform the following:
1. Power the copier OFF.
2. Access the 47 mode (power the copier ON, while pressing the 4 and 7 keys), output code 51.
3. Press the START/PRINT button.
4. The number 51 flashes in the display for approximately 90 seconds.
5. When the number 51 stops flashing, the adjustment is complete.
6. Power the copier OFF/ON to exit the 47 mode.
