The newer eStudio range can scan and copy at the same time but with the limitation that resolution is fixed at 600dpi. Are there any other manufacturers that can copy and scan at the same time with selectable resolution?
Toshiba estudio copy and scan
Balguy
Scans can be set to different resolutions but when you create a template selecting copy and save as file the scan settings pop up window does not let you select a resolution. Hence my original questionComment
Templates are designed to be preset settings that can be retrieved by a quick selection process. They are designed not to be changeable. Standard selection process will allow change. Unfortunately that is the way Toshiba looks at templates.And Star Trek was just a tv show...yeah right!Comment
