View Full Version : c452 552 652 image chips
big jase
08-10-2010, 11:59 PM
i have purchased a set of color chips ,but after stripping down the iu i can not see where this chip fits
has any one replaced any of these ,if so please help
see pics of iu chip i have etc5729573057315732
tcs04
08-11-2010, 08:07 PM
Which IU did you strip ?
Albonline
08-11-2010, 08:57 PM
flashing to the special firmware renders rechipping unnessary.
big jase
08-12-2010, 12:48 AM
it was the yellow iu i stripped down
what is the special firmware Albonline..how does that work?
mmru4real
08-12-2010, 01:13 AM
the special firmware allows you to turn off stop at end of iu life essentially allowing it to run until the cows come home without replacing until copy quality problems occur
big jase
08-12-2010, 01:51 AM
does end user still get message that iu needs replacing....what version is firmware
ck1
08-12-2010, 02:33 AM
you take wrong pwb , this is tcr sensor not the drum chip . you photo chip at the first is black color chip , not the yellow. ( sorry poor english )
Albonline
08-12-2010, 02:29 PM
No, the latest special version will even clear the message after it triggers. look it up on konicas tech web.
jdallagrana
08-17-2010, 10:42 PM
Albonline, What version, and where on konicas sight? I looked through ssd. any help would be great.
Stirton.M
08-18-2010, 12:53 AM
On SSD, if you look up the keyword "IU enhance", you should get the details. This is only effective for C250 and newer colour series machines.
jdallagrana
08-18-2010, 03:29 PM
thankyou very much. found it
emujo
08-18-2010, 04:46 PM
This fuctionality is built into the 652/652DS/C360 family. You have to set the soft switches correctly, but no firmware update is needed (although I would rec upgrading to B4 ASAP). The firmware upgrade is only applicable to the C203 through C650 family. The user will still see the oil can displayed, but MFP will not stop and IU replacement is elective versus mandentory, and no messages on the LCD to replace IU. Emujo
ebm
08-18-2010, 06:48 PM
What softswitches disable the "End of Life" messages on the C652 and C360 family machines? I tried switch 51 on a C360 showing "Replace Drum K" and it did nothing. Switch 50 only allows black ready ACS. TB6901 disables the prohibiting of copying past the end of life, but it does not eliminate the message on the display. TB7528 is only for the C353 and C650 family machines which "eliminates" the "need to replace" message. I would really like to know how to disable the "Need to Replace" messages on the newer color models. Thanks
jdallagrana
08-18-2010, 07:20 PM
TAUS0647606EN05, TAUS0703722EN01, TAUS0802098EN00 on Konica site may help
emujo
08-19-2010, 07:24 PM
Sorry gents (and ladies) I was given bad info on the C652/C360. The IU will suspend printing 5K copies past the end of life message. However, I believe KM will offer firmware to make this available on the C652/C360 once they are sure we don't screw up the C650 series by allowing them to run past their life spans. Hope no[one went crazy trying to set this up. Emujo
Stirton.M
08-20-2010, 02:48 AM
The C652 series, the black units are split apart, the developer and the drum unit separate, and the developer is constantly refreshed with new developer from the "toner bottle". Life span on the dev unit is 1,140,000 prints, while the drum unit is 295K. The colour IUs between 120-135K depending on the model speed. This is pretty significant over previous generations of our machines.
The C360 series, all the dev units and drum units are separate, the black dev unit, like in the C652 series, is also fresh exchange developer system, yields 570K, while each dev unit is 114K. The drum units, black yields between 70-120K depending on model speed, while the colour drums are between 55-90K. Not near as good as the 652, but still pretty damn good. The older C350 could never attain that life rating.
I have yet to hear anything about IU enhance on these series, but I would not be surprised if that is in the works.
Generally however, I have noted that the life of many consumables of the newer tuxedo series machines, that generally when they reach EOL, they really are at the end of their life and should be replaced regardless.
progoffice
11-14-2011, 08:41 PM
I just ran into this today for the first time. I came with chips in hand to take care of the color imaging units. I was unable to find any chips in the units. I can clearly see tabs where a chip might be installed but there was not one there. So my question is, where are the chips in this model? These are the original units that came with the machine, so is that why there is no chip installed?
I'm assuming there are chips in them since they can be ordered.
Has anyone had luck with the modified firmware?
Thanks.
Albonline
11-14-2011, 09:27 PM
those are the factory installed imag units. they come with no chips. install the chips you should be ok
progoffice
11-14-2011, 09:53 PM
I don't remember seeing a connector to plug the new chip into. Do the original imaging units have the chip connector if they ship without a chip? What I gather from other posts is that you have to buy a new set. The new sets ship with chip installed - and also connector for chip too I'm assuming???
Thanks.
yianni
09-14-2013, 02:36 AM
I don't remember seeing a connector to plug the new chip into. Do the original imaging units have the chip connector if they ship without a chip?It seems that the starter IU (those comming with the machine) don't have a chip neither the connector to connect the new chip.
PeterG
09-16-2013, 07:01 AM
As has already been stated, the original iu's that ship with the copier don't have chips or the harness to install the chips.
You can however remove the harness from expired replacement iu's & install it in the once used original image units, then either replace or reset the chip
stefanv
09-21-2013, 06:54 AM
The iu's in a new mc does not have the chips, its factory reset....Only the replacement iu's have the chips...You will see your connector on iu only has wires for tcr sensor...
