View Full Version : bizhub 7145
tlc1234
08-11-2010, 10:00 PM
i have a bizhub 7145 can scan but not able to print. is there a way to turn on print server has network conection on back of copier but printer setting not lighting up only scan and fax.
RRodgers
08-11-2010, 10:36 PM
If I remember right you have to add on the print kit and they did scan right out of the box.
copytechman
08-11-2010, 11:25 PM
You need to add the printer option module IP-432. Otherwise no print!
Regards!
A.
TheOwl
08-13-2010, 03:48 AM
The first two replies are spot on.
To check if you have a print controller, look to the left of the machine right near the back panel and about half way down you should see an empty hole (presuming that you don't have a print controller all ready).
