View Full Version : c350 hv1
jackson007
08-12-2010, 11:46 AM
sir
one of our costomers machine c350 is showing C 0204 code.is it hv 1 problem.plz help me sir
ineo+6501
08-12-2010, 11:49 AM
C0204 Yellow PC Drum Charge Corona
malfunction
jackson007
08-12-2010, 02:04 PM
what i have to do,clean the i u unit. or replease i u (but it is only25000 copies life)
ineo+6501
08-12-2010, 02:43 PM
Assuming this is a C350, you can attempt to clean the charge corona using the blue wand attached to the Yellow unit by pulling it in and out.
Failing that, replace the whole unit with a new one if you are not a tech.
jackson007
08-13-2010, 05:55 AM
sir,
i am a tech rep I can abel to open and nlean ,but what i have to cleanproperly.
ineo+6501
08-13-2010, 08:48 AM
2.6.23 C0204: Yellow PC Drum Charge Corona malfunction
Relevant Electrical Parts
Imaging Unit /Y
High Voltage Unit/1 (HV1)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
1 Check the Imaging Unit contact and correct or
clean as necessary.
2 Check the HV1 contact and correct or clean as
necessary.
3 Change Imaging Unit. — —
4 Change HV1. — —
5 Change PWB-MC
jackson007
08-16-2010, 10:10 AM
[QUOTE=ineo+6501;158075]2.6.23 C0204: Yellow PC Drum Charge Corona malfunction
Imaging Unit /Y
I replaced imaging unit but it is showing same
mrwho
08-16-2010, 10:52 AM
Before fiddling with the machine's boards and wiring, have you checked the contacts at the back of the machine to see if they're making proper contact with the IU?
ineo+6501
08-16-2010, 02:39 PM
Changing the imaging unit is the 3rd step in correcting this fault. The 1st and 2nd step need to be completed before changing the IU.
It is likely one of the contacts.
