View Full Version : Konica Minolta Bizhub 350
tech9
08-16-2010, 05:44 PM
Hi there i am not familar with this box do mainly xerox can any one point me in the right direction ? Konica Minolta Bizhub 350
PROBLEM: fault code c- 0f32
albasoul06
08-16-2010, 06:22 PM
COF32 is displayed
CAUSE: Poor connection between the imaging unit contacts and the machine. Defective ATDC sensor.
SOLUTION:Verify all connections between the ATDC sensor and the machine are clean and connected properly. If the code persists, replace the imaging unit.
C-0F32 is displayed.
CAUSE: Improper operation of sub-hopper sensors.
SOLUTION: Check to make sure the sub-hopper empty switch and magnet assembly are operating properly.
tech9
08-16-2010, 06:30 PM
Thanks mate will check it out in the morning !
fixthecopier
08-16-2010, 11:36 PM
Is this a Bizhub 350, or a Di 350, there is a difference. The code makes me think Di350. The info given was correct. Just change the image unit.
