View Full Version : Bizhub C550 Black Toner replaced - doesn't recognize - still shows empty
Shawn Jones
08-18-2010, 08:50 PM
Hello, Monday I replaced the toner cartridge. At first the symbol showed it was full but the message still stated (K) toner cartridge low - replace. Today, the toner cartridge symbol shows it empty and we still have the message to replace. Is there any way to reset it? I've tried shutting the machine down. I'm not an actual technician, but I take care of the machines. Any help is appreciated. Thanks.
Stirton.M
08-19-2010, 12:06 AM
Solution ID TAUS0801925EN* Solution Usage
Description
Low toner indication message.
Solution
CAUSE: When putting a new toner cartridge into the machine, a low toner message will indicate on the LCD.
SOLUTION: Shake the cartridge before putting it into the machine as it may have compacted toner from shipping or sitting on the shelf.
__________________________________________________ _____
Solution ID TAUS0801403EN* Solution Usage 1
Description
A few minutes after installing new toner the machine indicates that it is empty again and that the toner cartridge needs to be replaced.
Solution
CAUSE: The TLD sensor in the hopper has failed.
SOLUTION: Replace the TLD (p/n 40AA 8803 1).
Solution ID TAUS0802340EN* Solution Usage 1
Description
"Install toner cartridge" message for C, M, Y or K after toner cartridge(s) installed.
Solution
CAUSE: CN29 on PWB-MC (upper right hand corner of board) has been dislodged or is partially connected.
SOLUTION: Reseat CN29 on PWB-MC.
Solution ID TAUS0900694EN* Solution Usage 0
Description
Solution
CAUSE:Connector CN57 in harness to PRCB has been dislodged or is partially connected causing machine not to read Toner cartridgeEEP-ROMs.
SOLUTION: Reseat connector CN 57 in harness to PRCB.
Solution ID TAUS0902847EN* Solution Usage
Description
INSTALL TONER CARTRIDGE FOR ALL FOUR COLORS message on the operation panel.
Solution
CAUSE: The PRCB has failed.
SOLUTION: Replace the PRCB, (p/n A00J H001 06).
Solution ID TAUS0801188EN* Solution Usage 7
Description
After installing a Black (K) toner cartridge the machine still indicates that Black (K) toner is low.
Solution
CAUSE: The toner bottle drive unit for Cyan and Black (K) has failed.
SOLUTION: Before changing the toner bottle drive unit be sure that CN-29 (see attached for connector location)on the PWB-MC (PRCB -p/n A00J H001 06)
is connected properly. Disconnect this connector and reseat it. If the issue of low toner still remains when theMFP isrestarted, replace the toner bottle drive
unit for Cyan and Black (p/n A00J R713 00).
Solution ID TAUS0801202EN* Solution Usage 4
Description
REPLACE TONER SOON messageafter replacing the black toner cartridge.
Solution
CAUSE: The black toner cartridge/bottle drive has failed.
SOLUTION: Replace the black bottle drive unit (p/n A00J R713 00).
Solution ID TAUS0801619EN* Solution Usage 3
Description
"Install toner cartridge" message for any color after replacing toner with new cartridge. Toner cartridge is full and indicator shows full.
Solution
CAUSE: Toner grounding clip in front of toner cartridge is out of position. It reads the toner cartridge life control chip on the toner cartridge.
SOLUTION: Reposition the grounding clip so that itmakes good contact with the toner cartridge life control chip.
Note : Check all toner cartridge grounding clips, as the wrong unit may be indicated on the panel.
And firmware may be corrupt. Reflash machine with current level firmware.
__________________________________________________ _______________
This issue you will have to call for service, as is evident by the previous known issues.
Shawn Jones
08-19-2010, 12:18 AM
Thank you so much! That's very helpful.
