View Full Version : Error Code c-D048
stewart
08-20-2010, 07:56 AM
hi all
need help on this one C-D048 error library do i need to format and reinstall or new hdd
thanks
Stirton.M
08-20-2010, 10:10 AM
I think this is the second post you left without a machine description.
I'm not giving you any answers anymore until you get that point.
stewart
08-20-2010, 12:21 PM
sorry stirton.m and everyone but new to this the machine is a c280 the error is d084 will i have to format and reinstall or new hdd
thyanks again
Stirton.M
08-21-2010, 04:59 AM
This particular code, to clear, requires to turn off the main power switch. Do not use the "sub power", it is not the same thing.
In the case of a recurring failure, you may have to go deeper. I have yet to see this type of error on any machines I work on. The manual does not reveal any "fix" aside from the power switch.
The drive itself may be failing but to know, you can try formatting the drive. Use logical, it is reasonably fast. The other choice takes forever.
Swapping the drive will reveal if it is the drive, or the PRCB that is failing.
RRodgers
08-21-2010, 06:18 AM
Hi guys... I can't put toner into my copier. Can you help? Please!! I need to make copies NOW!! lol
