Will
08-24-2010, 02:49 PM
Have a NEC IT3530 which is similiar to a Konica Bizhub 350 but resetting a C2557 error
on the NEC is different than on the Konica cause screens are different in diagnostics.
Does anyone know how to reset C2557 on the NEC IT3530? Just repalced with new
developer unit and developer with brand new Konica 350 developer unit and drum and can't even get in to run F8 til I can reset C2557. Are developer units the same they look identical side by side?
Have tried reinstalling old unit and can reset C2557 but fault returns with new developer unit. Also tried switching ATDC sensor with the one out of the old developer unit, so I
know its not the ATDC sensor cause it works in the old developer unit and yes I'm using new DV-310 developer. The only item that is different is the drum & blade are generic but have used them before without problem.
